SOURCE: Chuck tines on Ryobi Hammer Drill Are Not Engaging Uniformly
home depot replacement chuck i beleive you can also us a keyless chuck. they usually come with instructions. most have a screw at the inside of drill chuck.
tom
SOURCE: yamaha s2500 dvd player
Hello, frustrated Yamaha owners.
I have destroyed two of these machines to remove my precious CD's. I did discover this today:
1. There is a fuse but it is soldered onto its circuit board.
2. There is no easy way, like using a paperclip on the old computer cd-rom drives, to release the cd/dvd tray. However, when I destroyed my second player, I noted there is a rather large piece of metallic tape on the bottom of the player to the right side of the front of the drive on the metal bottom cover plate of the machine. It is covering a slot about an inch long. If you carefully remove the tape and use, say a phillips head screwdriver, starting at the right side of the slot as you face the front of the player, you can slide a plastic bar that will free-up the tray slightly allowing one to pull the tray out and save the cd or dvd. I would do this with the player upright but hanging over the edge of a table so that the freed cd doesn't bang around against something in the process.
For what it is worth, I hope this helps.
Yamaha should be ashamed of producing a product at this price point with an issue like this. At the very least there should be a fail-safe way of removing a cd/dvd from the drive regardless of the issue with the electronics or drive mechanism.
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
SOURCE: my hammer drill won't hammer.
when was the last time serviced?? If not recently then you would need to replace the o rings and look for other sticking/worn parts. Give me the exact model number and I will try and find you a breakdown and a rebuild kit. They are not that bad if you are handy with tools and take your time. Let me know
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help [email protected]
thanks
