Question about Electric Electrical Supplies
I have a Duro Max XP4400E 3500W electric start generator. New battery but will not start. Electric start is not turning over the engine just a whirring sound. Also will not start with pull
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I have purchased 3 of these duromax generators from return pallets all 3 had the same problem the spark plug wire was broke on all 3. With the xp4400E you can either repair the wire yourself or order a new one problem is the coil is connected to it. Local shop wanted $70 i think it was around $15 on amazon .
Posted on Jun 15, 2019
    New Friend:
    Problem Solver:
  • 9 Answers
Check the starter bendix. might just need lube or new one
Posted on Feb 04, 2018
SOURCE:
SOURCE: Brand new Generator not working
Take it back where you bought it with the sales receipt. Just about everything has at least a one year warranty, Anything that's well built should last AT LEAST one or two years. As long as it wasn't submerged, abused or dumped off the tailgate of a truck they should make it right for you.
Posted on Oct 22, 2008
  • 83 Answers
SOURCE: electric start will not work
You should remove the battery and charge it up outside the machine then take it to your local auto parts store where they will load test it for free. It must be fully charged to test. Most of the time those small batteries are dead due to the heat produced in the machine. These batteries only run about $30 or less usually.
Note: BEFORE CHARGING if the battery is not sealed ensure the battery water level is good (no exposed plates, usually the water is about 1 1/2" below the top of the holes). Use pure bottled water if you need to add water.
Posted on Mar 30, 2009
  • 205 Answers
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Posted on Oct 23, 2009
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
SOURCE: Electric start on 640 pulls dead
put bike into 2nd gear while on the bike and push backwards until the bike goes no further.put back into nuetrual.should start easier.works on my 640 when its slow to start
Posted on Feb 20, 2010
SOURCE: Need a replacement battery for my DuroMax XP4400E
12n6.5-3b
Posted on Oct 11, 2011
Can i buy a electric starter for my subaru generator
you would really have to check with the dealer or see if there is a place for one. some come with a starter upgrade and some dont
Sep 02, 2018 | Electric Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
Duro max xp4400 generatol is not producing electricity
Check power going to the breaker. Check the brush conditions and the trace condition.
May 14, 2013 | DuroMax RV Grade 4400 Watt 7.0 Hp Gas...
I have a Generac 6500E. The electric start turns over the engine but will not start. Pull start works fine
If the pull start works, but the electric start doesn't try the following. Either give the battery on the generator a full charge, and if after a full charge it doesn't start, get a new battery.
Jan 20, 2013 | Generac GP6500E - 6500 Watt Electric Start...
The electric start on my GP7000E clicks, but does not crank the engine. I've had the battery charger plugged in for several hours. Is it the battery or the starter?
mines doing the same thing, brand new, I think its the battery as soon as I hit the start button battery voltage goes to 5 volts
Oct 28, 2012 | Generac Gp7000e Portable Generator
My 2007 Toyota Highlander Hybrid didn't start this morning! I turned the key, and everything went off. I could hear the electric engine trying to start, but that was it. The fuel engine never started. The...
the aux battery is bad its uder the hood the generator does start the gas engine but you left the dome light on or something like that it will not turn on or switch to ready mode
Feb 24, 2010 | 2007 Toyota Highlander Hybrid
My onan generator voltage is around 127 to 129 volts but wont run a space heater what is the problem i changed the fuel filters
First thing you need to do is turn down the engine speed and get the voltage dow to max 120v, Then chk the heater. Excessive voltage will ruin appliances. .
Nov 17, 2009 | BUFFALO ACDelco 6500 Watt Generator...
Add electric start to dg7000 generator by Dewalt
This is really not an option. The engine would need a starter motor and battery and starting key switch. You will probably have to replace the unit with an electric start option.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 08, 2009 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Electrical Supplies Logo
177 people viewed this question
Top Electrical Supplies Experts
Fahr Quad
NOEL
NOEL
vince
Are you an Electrical Supply Expert? Answer questions, earn points and help others
