Question about Samsung Washing Machines
Samsung front washer WF203ANW will not drain.
The drain hose is not blocked. Will drain on spin cycle if drain hose is laying on the ground also have tested the pump and it runs if I put power to it
    Sergeant:
  • 250 Answers
Have you tested for power to the pump when in drain cycle? Could be relay or wiring issue
Posted on Jan 21, 2018
SOURCE:
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Posted on Dec 19, 2007
SOURCE: kenmore he2 front load washer
Open the panel with 1/4 in socket. Turn white plastic cap filter counter clockwise. remove debris. replace. Run rinse and spin cycle. reopen cap and check for any new debris. replace filter cap and put cover back on. put $65 in bank. Send note to Eddie Lampert and tell him that Sears sucks and he'll never save it as long as they keep screwing their customers by not telling them about a simple fix like like this to an obviously common problem.
Posted on Jan 28, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
I have a top laoder whirlpool8564990 it don´t spin well it leaves my clothes soaked and it goes to spinning cycle yet it don´t spin
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Washing Machines
Amana front load washer has wet clothes after the complete wash cycle finishes
Oct 13, 2016 | Amana Washing Machines
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
Oct 13, 2016 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Zanussi zwf1437w
Possibly blocked sump hose( bottom of drum) or pump not running,,,,drain water by putting outlet hose down too ground level, when water drained out put machine on spin. If machine spins ok, then you have a pump problem,,,,if water won't drain out when outlet hose at ground level then you have a blocked hose
May 25, 2013 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Front-load washer will not spin. while draining (i assume) it makes a loud clicking noise. It sounds like something is trying to turn but is not catching/moving. I have put it on the spin only cycle and...
You may have a broken or jammed drain pump and it needs a technician to disassembly the pump to see if the pump needs to be replaced or remove the debris inside it. Good luck
Jun 19, 2011 | Samsung WF203ANW Front Load Washer
Hi! we have a GW609au Fisher & Paykel washing machine with lights 3,6,& 8 displayed during spin cycle. Does not spin. What does this mean please?
It's error code 37 and it means pump blocked error. The machine does not spin because water is not drained prior to the spin cycle. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Also check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diveter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Dec 29, 2010 | Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
My wife restarted the rinse cycle to add fabric softener. Now the cycle timer isn't working. Washer will not drain OR spin. Everytime the timer gets to the spin cycle, it agitates instead. It is a...
Lay the drain hose down to floor level, and drain of the water into something.
Then try it on spin, if it spins o/k, then the pump or filter is probably blocked.
Hope this helps.
Jan 19, 2010 | Indesit W 123 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
