SOURCE: how to change day of week on tommy bahama watch
Pull the crown out to the first click and then turn the crown. one direction changes the day and the other changes the date. Push the crown back in and you are done.
Hope this helps,
Ken
www.yellowstonewatch.com
SOURCE: I need a manual for a Tommy Bahama model#: TB3021
Go to http://www.genevawatchgroup.com/ and on the menu on the right there is "customer service", click on this and scroll down until you reach the instructions for your watch.
SOURCE: How do I change the
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
SOURCE: how to set time in
Follow this link: http://www.tommybahama.com/TBG/GeneralContent/CustomerService.jsp Then click on the right side "Product Information", then look for "If you would like to view and download instructional manuals for your watch, please click here." and click on it. Then you will be able to choose your watch type and get instructions for setting the time.
