Way late but if not fixed here ya go...
Look in the bottom right corner of your Wolf cooktop. A key symbol glows when the cooktop is locked. Press and hold the glowing key symbol for three seconds. The cooktop emits three chimes and the symbol stops glowing when the lock is switched off.Hold the key symbol down for a further three seconds to reactivate the lock.
SOURCE: need help to unlock the cooktop
You will have to hold the lock button down for 3 or 5 seconds for it to unlock. If this doesn't help, it could be a stuck key pad or a problem in the circuit board.
Thanks/Mike
SOURCE: electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
SOURCE: Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
SOURCE: Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
did you get this fixed?
