Pulsar duel language day date
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
SOURCE: directions to change day and date on old bucherer automatic watch
Try this: pull out the winding crown to the first click and change the
date. Memorize which way the crown turns to do that. Now turn the crown
in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
SOURCE: Calendar "Day" is stuck beteen days
pull the dial out half way, and turn it forward to adjust the day, and dial it backward to adjust the date.
SOURCE: Date Changes during the day
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Testimonial: "Perfect- very detailed and easy to follow. Thank you!"
SOURCE: Need instructions on how to
Some of these can be quite a bugger to set, there are so many variates of Pulsar watches, and I'm not able to locate exact instructions for that model. However if you call Pulsar with that model number they will gladly provide a free manual for you, one you can probably even download and view, or they can email it to you directly. Please call Pulsar at 1-201-529-5730 and request the instructions.
Thanks
Tim
