SOURCE: Installed a new Kohler model
2 possibilities.
1) The diaphragm in the Sloan is for a urinal. (1.0gal vs. 1.6gal);
2) Not enough water. (stop partially closed, supply undersized)
SOURCE: Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. [email protected]
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
SOURCE: Wall-mounted toilet has a crack and is leaking.
If you don't care about seeing the repair use the product that Smithbrother recommended it works great. Other marine epoxies would also do it. They can be purchased in any hardware store, including the box stores like home depot and lowes.
SOURCE: How to adjust water level in tank---Kohler Wellworth toilet
please make sure the water is off!
the fluid master has a slip ring at the bottom of the float base it pulls up then you can adjust the float up or, down and, snap it back down.
at the top of the float you will see a cross-headed plastic bolt; this is adjusted for fine level control using a large conventional philips screwdriver.
