I have Windows 10 and MS Office 2013
This link would better explain your issue and has the best solution.
Ihope that will fix the issue...
Dragon Naturally Speaking Playback is not working in Word document
SOURCE: Compatibility with Dragon Naturally Speaking
This problem was not fixed. Agent gave up on me and disconnected
SOURCE: I cannot save my user files in Dragon Naturally
Instead of "Save" files, use the "Save As" option.
SOURCE: I accidentally deleted my built in microphone
go to dells website find drivers and downloads input your model where asked and itll find your driver.
SOURCE: No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
SOURCE: syncing Sony ICD-MX20 with Dragon Naturally Speaking 10 on Vista
the workaround seems to be
buy an Olympus recorder (supposedly they issued a patch for DNS 10 in a couple of days)
or
tell DNS that the source is a PDA generating WAV, MP3, etc.
havn't tried this myself yet. some say it it isn't that awful. But I too am very dissappointed.
