Humidifiers Logo
I have a venta vs205 humidifier. the red light blinks. how to solve
1 Related Answer
Anonymous
  • Posted on Dec 20, 2011
SOURCE: Venta Sonic VS205 Humidifier turns
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
3helpful
3answers
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
The humidifier will not turn on ---only a faint blinking light when I push the power button or the other buttons---no humidified air is coming out no matter what I press/
http://www.airkinglimited.com/airking/admin/article_instructions/5000IO.pdf
Here's a link to the install manual.
Check out the section on setting the dip switches, it may help.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
2answers
Venta 205 no mist
Throw the unit out - it's garbage
29helpful
5answers
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all summer (followed the manual instructions) and it's the first time I'm turning it on.
I had the same problem. During the cleaning process, the white float was installed upside down and humidifier water level sensor was unable to read the float. I removed the phillips screw and inverted the float with the dark ring toward the bottm. Quick fix.
Venta humidifier is not humidifying much.
Buy a new filter cartridge. www.ventahumidifiers.com
6helpful
4answers
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Top Venta Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
