Check your sample. Is it the top thread that is looping under the fabric? That is called bird nesting or thread nesting. It happens frequently if the top thread is not seated completely in the tension disk. It could also be a top tension problem.
Be sure to use a brand new needle compatible with the thread and fabric.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point and test on a scrap of the same fabric. Adjust the top tension until the top and bobbin threads meet in the middle of the fabric. (Tightening the top tension will pull the bobbin thread up. Loosening the top tension will allow the bobbin thread to pull the top thread down.)
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
SOURCE: singer 5525 sewing machine knots
You can go here, search 5525, and download or purchase an instruction manual for
your machine, if you have misplaced the one that came with it. It looks
like there are some available as downloadable pdfs for free and some physical ones for $15. https://www.singerco.com/accessories/manuals.html
Also, Singer has just installed new Q&A features on their website.
You can
go here: http://new.singerco.com/products and look for your
particular model or machine category. At the bottom of the product page, you can post
Questions for singer experts and other community members to answer!
Good
luck!
SOURCE: I have a Singer 4832 c. I can't find my manual.
check to see if your needle is bent
check your tension
if you need a manual go to diplodocs.com
in the center on the page select brand-
your is there under singer
then product look up model number
manuals are pdf & free
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
