SOURCE: prolite e435s iiyama screen
Monitor screens will have color tints when any of pins of the VGA connector is damaged or bent(I assume you are using a 15 pin VGA connection :) ) Please remove the monitor connector cable and check if you have bent or damaged pin at either side of the cable.
If it does not resolves the issue, replace any devices or equipments that may have electro magnetic fields like an UPS from the premises of the monitor.
Also, you can try resetting monitor. All the monitor will have an option for reset in the Menu.
Hope this works!
Good Luck
SOURCE: colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
SOURCE: iiyama ProLite E481S random shutdown
Your welcome. I hope you get satisfaction and this problem is taken care of in your favor. In looking up the phone number for you to call, I noticed the price on this monitor, it is in the high range. Seems a shame a small part can take you down but it does happen. So, don't feel alone. Stick to your guns and don't give up until you get satisfaction from this company.
Regards,
Worldvet
Thanks for boosting the rating. It mean a lot to us here. We don't get paid by the hour or anything like that. What we do, most of us have been doing for free for years. This site has a bright future as they pick up relationships with vendors. Tehre are certain requests, where we do get a token payment of four or six dollars. Most of us use this money on our own Power Computers to buy high end parts.
Again, good luck and you may ask for me anytime.
SOURCE: Volume increases by itself
This could be a sticky button or a bad key controller! The key controller is the button board, this stream the commands to the main board (main unit). not to hard to replace, if your somewhat handy! But will require the case (back panel) to be removed. Good luck, hope this is helpful!
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
