SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: Just bought sed Jazzy Select for my wife. Chair
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
SOURCE: Constant flashing lights,all three of
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
