Computers & Internet Logo
S
Susan Morris Posted on Jan 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I activate my webcam camera on MSI L1350D netbook?
Larry Ng
Level 3:
Top Expert:
  • MSI Master 14,598 Answers
  • Posted on Mar 23, 2022
Larry Ng
MSI Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3279083
Points
66616
No OS told
but at MSI.com
get the drivers
and load them
and if this PC has a cam, (vast do not or is and option then)
it works.
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on May 23, 2009
SOURCE: acer aspire one netbook - webcam on yahoo doesnot work
click on these 2 Click1 Click2 these are acer files
Anonymous
  • 290 Answers
  • Posted on Aug 08, 2009
SOURCE: how to activate webcam (msi U100)
you can activate that msi wind u 100 webcam when it is being installed on your system. You will be needing a driver installation source in order to use the device. the reason why you need these drivers, its because it allows the device to be recognized by the operating system .
you can download drivers for free at the manufacturers website.. :)
Hope this will help you out..
Pm me with your operating system and the model of your webcam if you want me to download the drivers for you..
Thank you :)
Anonymous
  • 1188 Answers
  • Posted on Jan 26, 2010
SOURCE: MSI U100 :S
I believe holding down the Fn button (on the bottom left of the keyboard) and F6 turns the webcam off and on. If it is off, it won't be seen by windows at all. Just hit Fn and F6 at the same time and you should be all set. The F6 key even has a small picture of what should be a webcam.
EJ
Anonymous
  • Posted on Aug 22, 2010
SOURCE: msi u100 windows xp sp2 - build in camera activation
have you tried :
1) Fn key ( Hold that down , it is located at the bottom left of your keyboard)
2) while holding that down hit f9 to turn it on
It gives you a confusing message when its not turned on and a lot of people think that its a driver issue :)
Anonymous
  • Posted on Sep 26, 2010
SOURCE: My msi wind u160 netbook
your webcam is almost certainly turned off. press "fn" (function key) + f6..as you may see f6 has the camera icon as other keys have secondary function that works if u press while holding the "fn" key. hope that helps ^_^
How update BIOS msi l1350d?
What brand and model of computer is this for?
1helpful
2answers
How to turn on wifi on my notebook msi l1350d
You probably have the answer by now but press the Fn and F11 keys at the same time until you see the wireless logo pop up.
I have a MSI L1350D , it is working i can see myself but, i can't find anything to click on to capture a picture of myself or record ,,,any suggestion /?
Hello
You can use a free program like simple webcam capture from here:
http://www.softpedia.com/get/Internet/WebCam/Simple-Webcam-Capture.shtml
Hope it helps.
How do i get my webcam working for my msi L1350D?
Hi, I'm Naldz . If your web cam is new, there is a small disk that goes along with the package. Use this mini disk to install the driver that your computer needs in order for your web cam to work properly with your netbook computer. I hope this would solve your problem.. Have a good day !
1helpful
I have a MSI laptop computer model L1350D and I am have trouble turning the bluetooth on. Wilo
Press and hold the Fn button, and then press the F11 button to enable or disable the Wireless LAN/Bluetooth/3G/WiMax function.
4helpful
2answers
There is no webcam driver so the webcam is not working
This netbook comes preloaded with Windows 7. Window 7 contains a preloaded driver that supports this camera. I fthe camera is not working, i would delete it and have Win 7 find it again. To do this, start/control panel/system/device manager, find the imaging / input device where the driver would be installed - should be fairly obvious - "webcam" or "camera" label, right click and choose uninstall. Reboot computer after you do this. On bootup, when you reach the desktop it will search and find the webcam.
1helpful
2answers
While doing video call getting alert webcam not connected msi L1350D pls advice solution thanks
MSI states that "This device uses the native driver bundled in operating system."But the driver may become corrupt, so you'll need to remove it first then re-discover it. To do so, follow these instructions
Go to Start\Control Panel\System and Security\Device Manager
Go to Imaging Devices, you should see the camera there. Right click the name of your camera and choose uninstall. After it gets deleted, go for
Action\Scan for hardware changes. It should discover your camera automatically.
If it still doesn't work, check your video calling application for video camera setup.
13helpful
2answers
Msi l1350d web cam wont show up its almost as if its not there! looked on msi website they say the driver is not downloadable
Press the F6 Button - this will install the webcam driver. Give it a few seconds untill the "Device Driver Installed Successfully" message comes up, and the camera should work
1helpful
Msi wind l1350d Where is the memory slot cover?
Depending upon the model it could be on the bottom of the laptop or under the keyboard.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
