I have gone through all the menus related to closed captioning I can find and cannot make it appear while I am watching TV through my Cox cable box. Closed captioning does appear on the external Roku. What should I try next? I turn CC on using the cable's remote, and it is on using the TV's remote.
Turning Closed Caption Off or On
Depending on which type of equipment you have with Cox, the steps are shown at the above link.
Some programs do not support closed captions at all.
SOURCE: Sharp Aquos LCD TV 52"
Its in the TV Setup. The Cable box will output the Closed Captioning on
Line 20 or 21 of the Picture - this is just at the top of the TV
Picture where you can't see it. The TV Menu should have a choice of
closed Captioning like CC1, Teletext, etc. and one of them should be
selected. After exiting the menu, you should start seeing Closed
Captioning
on the tv.
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
SOURCE: Can't turn off closed captioning
CC is either active on the Cable Box or the TV, check your settings on both.
SOURCE: HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
