SOURCE: usb driver for w302 won't work
Kindly check this link. And on the right-hand side, you will see the available USB drivers:
http://www.ab-archive.com/search.php?kw=driver_modem_usb_se_w302
One of those USB drivers might work with your phone.
Have a great day!
SOURCE: pc suite for sony ericsson W302
You don't need software to do this.Fitrst you need to add your your phone as a bluetooth device.If everything worked allright then there should now be a Standard Modem over bluetooth in your Phone andmodems control panel.Then you need two services to be running, goto taskmanager and set both Remote acces connection and Telephony to automatic (right click>properties) and also start them both.
Now go to Control Panel Network and sharing and click Setup a network connection then choose connecting to the internet then choose dial up connection then choose Standard modem over bluetooth , type *99# as phone number leave the rest blank and there you go , you have a internet connection over your mobile.
Good Luck
SOURCE: pc suite for sonyericsson w302
I have searched and searched for you and just when I thought I had found what you needed I came to a dead end. I did find Sony's phone number for you to call. One is toll free so hopefully Sony can help you. Good luck!
Here is the link to the website with the phone numbers:
http://www.sonyericsson.com/cws/common/contact?lc=en&cc=in
SOURCE: i want to transfer my contacts from outlook express to w302
Sir, Use MyPhone Explorer. It will not only transfer your contacts but is also a complete solution to all your Sony Ericsson sync issues.
http://www.fjsoft.at/files/MyPhoneExplorer_Setup_1.7.3.exe
You must also download USB drivers for your mobile before using this software.
Download USB drivers here
http://www.sonyericsson.com/cws/download/1/579/333/1240902134/USB_Drivers_setup_v0.0.0.9.exe
Export your contacts from Outlook in "VCF" format and import them in MyPhone Explorer. After been imported sync your MyPhone Explorer's Phonebook to your phone using the Sync Button.
If i was helpfull, kindly do rate me.
Regards,
Waqar
SOURCE: How to install theme in sony ericsson w302
just paste the thems in the themes folder and there u go....
