SOURCE: xbox 360 modding
You cannot transfer files to the Xbox 360, you can only stream the material eg songs or videos through it. You can put the items you wish to view on a usb memory stick, but again you cannot save them to your XBox 360 only play direct from the device you use to store the videos or music. You will also need XP media centre to use the media extender software, or even better Vista premium, XP home or Pro will not share the material with XBox because it cannot use the extender software.
SOURCE: Xbox 360 Keeps Crashing
buy a fan for your xbox 360, if it continues contact microsoft and see if they have a solution, it could be an internal problem that needs repairing, i have the same problem but i am going to get a fan which will cool the 360, and reduce the chance of my 360 breaking
SOURCE: i need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
SOURCE: gta IV won't work on my xbox 360
it has to do with your tv if you have a 50 pal tv u will need a 60 pal because the grafics are good
