SOURCE: just bought a disgo 8000 android tablet but it freezes every time I try to use the gallery
Hi there, We are
sorry to hear that the device is freezing and not working as expected. Please
try the following which may help to resolve the issue. Thanks,
mydisgo.com
1) Ensure that the Video/Image files you are trying to view are compatible with
the tablet. Compatible files are located on the packaging and in the User
Manual. You can also locate this information on the website, mydisgo.com
2) If you have not already done so, we would advise that you update the device
to version 2.3. The update procedure can be found at the following page; tinyurl.com/8000update
3) If the Gallery app only freezes when accessing files on the SD card (and
not internal memory), please try using the alternative memory card slot or test
using a different memory card.
I do hope this helps to resolve the issue.
If you require any further assistance, please do not hesitate to contact us at
mydisgo.com/support
SOURCE: how to reinstall android 4.2.2 jelly bean in nextbook 8
You could download a JB rom for your nextbook 8 and flash it using live suit or do a factory reset by turning it off then hold down the vol up button then hold the power at the same time until you get recovery appear then you can do a factory reset.
Testimonial: "I have tried the factory reset with power/volume button. First screen is NO COMMAND hit up volume did reset and same. where is reset button on back. Only have speaker holes."
SOURCE: My son click n kids tablet Android 4.1 freezes a
If this is a new device check to see if it needs some program updating.
This is just a guess before it froze did you set a sleep timer? If you left it on with no sleep timer the image might have permanently burned into the screen
