You will need to obtain a completely new power cord kit from the manufacturer. If you are not familiar with doing electrical repairs, you may want to have a technician do it. Insulation on the power cord is important for several reasons; especially a method to keep you safe from a fire, electrical burn, shock, etc.
SOURCE: Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
SOURCE: The iron is dripping water when in the steam mode.
try less water and distilled water not tap water.
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
SOURCE: Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: My steam cord outer covering is all frayed at the
This the link you can use to order new parts for your iron,
http://www.unbeatable.co.uk/spares/tefal_irons-parts-repairs.html
