That is a bad computer board or control board same thing.next time send the model number go here put your model number in and you can look up all the parts in your machine open the door look around the opening where you put the clothes in you'll see a tag with model and serial numbers.
https://www.searspartsdirect.com/model-number/ETS22SBPBRBS/0432/0166000.html?searchType=modelSearch&q=ets22sbpbrbs&searchTerm=ets22sbpbrbs
SOURCE: Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
SOURCE: F01 error code
I've fixed Indesit WITE 107 F-01 failure error!
We have the washer like 3 years and the F-01 error kept showing irregularly since one year ago - just after the warranty expiration. Usually unpluging the washer from the power supply solved the problem, sometimes immediately, but mostly overnight. When we moved from flat to country house, the problems frequency slightly increased. Till last couple of days it was still bearable. But in the recent days the error didn't even show up, and the motor was not turning at all. Just the pump was pumping the water in and out, so the program got hanging somewhere. So resolution became necessary. I've contacted tow servicemen yesterday, but none of them answered yet - well it's weekend. But as usually, when you ask for help, you'd find it on your own right after. So I decided to look at it myself.
- unplugged the washer power supply, closed the water
- unscrewed two screws that hold the control panel
- removed the panel - you need the lid to be semi-opened
- (re-conected all connectors to fix any possible oxidation or unpluging - then tried the washer, but problem persisted)
- unscrewed all screws that hold the side cover - only the right one had actually been necessary (when standing in front of the washer)
- unscrewed all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrewed two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver I've cleaned the contact together with the connector and tried the washer - still no effect
- cleaned the black wire connection with the same way
- tried the washer (spinning program) and - voila! It works!
- tried unplugging the black wire and running the spinning program - both the motor AND the pump didn't start
So, it looks to me that the problem was in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor, that caused insufficient voltage and thus a power for the motor but probably still enough for the pump. The randomness of the problem was probably caused by humidity in the room and maybe some more factors - the washer is actually opened from the bottom so when I test the washer more times and see this as a solution, I'll probably cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside. It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer. It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly
So if you are a bit handsome, try this before calling the service. It might help. And also you'll know your washer a bit more.
SOURCE: my amana dryer model is making screeching sound
Hi Peggy...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
BE REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
SOURCE: WHAT DOES F01 ERROR CODE MEAN AND HOW DO YOU FIX
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked.
The nd error code indicates "no drain". If the unit can't drain it won't
spin. You're going to have to slide the washer out far enough to remove
the rear panel; be careful not to damage the floor. Once you get the
rear panel off you will see the pump. Be sure to have plenty of towels
& a small container to catch water. I am sending you instructions
from the service manual to remove and replace the pump. Another
possibility is the drain line is blocked or something is stuck in the
tub to pump hose.
