Question about LG Dishwashers
I have AE error code LG dishwasher mode# LDF7774ST
    Habit-Forming:
  • 36 Answers
Http://www.lg.com/us/support/product-help/CT10000009-20150140938312-other-error-codes
Posted on Jan 14, 2018
  • 489 Answers
SOURCE: New LG Washer Dryer
Are you sure it's says AE for the error code.  LG doesn't list that particular error code.  Please check again.
Posted on Apr 27, 2008
stradeteox
  • 88 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Posted on Jan 18, 2009
onthejob5130
  • 640 Answers
SOURCE: LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Posted on Feb 04, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
ginko
  • 19396 Answers
SOURCE: How do i fix error
Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
Posted on Aug 28, 2011
AE comes on. Have not used the dishwasher. Just started today. How do I stop it from coming on. I can call LG tomorrow
The AE or E1 error code indicates a possible leak from the unit. This is most often caused by excessive suds overflowing into the base of the dishwasher.
This problem could be caused by a failure on your machine or the detergent used. I highly recommend you follow the troubleshooting from the LG website. HEre is the link.
LG Help Library AE E1 ERROR CODE DISH WASHER LG
Jun 28, 2018 | LG Dishwashers
LG Inverter Direct dishwasher shows AE and sounds like it's trying to run
The LG Support page has a Troubleshooting Guide for the AE error code and suggests it may be too much detergent being used.
Here's the link.
May 08, 2018 | LG Dishwashers
My dishwasher error code is AE what does it mean? I have tried to reset it but it still says that
If this is a LG dishwasher ... then the AE code means there is a leak somewhere underneath. On some models there is a small catch pan underneath that over time may accumulate some water which trips a sensor in the catch pan ... resulting in the AE code.
If that is your problem ... then resetting will not solve the problem since the water has not gone away. You need to take the front toe plate off and remove the water from the catch pan ... usually a paper towel can which it up as shown in the attached link.
AE Error LG Dishwasher LDF5545
You should also check all connections for leaks since over time the catch pan may fill again. Use a dry paper towel and touch all the connections ... if it becomes damp then you have a leak. (It is hard to just visually inspect for leaks)
Helpful?
Good luck on your troubleshooting!
Mar 03, 2018 | Dishwashers
Lg AE code
The AE error is
indicative that there is a leak
somewhere in the washer and it has
triggered the flood protection device
found at the bottom of machine.
For more information check the LG site: http://www.lg.com/ae/support/product-help/CT20076045-1442052868665-other-error-codes
All the best and Happy new year !
Dec 29, 2017 | LG Washing Machines
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
New LG Washer Dryer
Apr 19, 2008 | LG WM-2277HW Front Load Washer
Dishwashers Logo
3,220 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
