SOURCE: To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
SOURCE: Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
SOURCE: can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
SOURCE: Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
