Your drain pipe may be restricted try checking drain line for kinks, ensure proper drain rate is allowed from plumbing.
Or
you ca turn it off, wait 3-5 seconds, then turn back on. Sometimes you have to repeat this 2-3 times.
Or
if none of the above: contact your local Hobart Service Office
If you need further help, reach me via phone at https://www.6ya.com/expert/kelley_9a924afdf232bd4d
Water pump. This may be clogged or wrecked. Normally clogged. http://kitchen.manualsonline.com/manuals/mfg/hobart_corp/lxih_ml_130017.html?p=18
SOURCE: hobart LXiH
Hobart doesnt release service manuals but you can get an operation/installation manual for free here http://www.hobartservice.com/Manuals/ Im a service tech for hobart so if you have any questions let me know.
SOURCE: LXIH, ML #130017
hi there have you checked that the drain pump is pumping out the water fast ehough, sounds like you may have a blockage problem and the programe is timeing out ie. not draining within the specified time, for example 3 mins
SOURCE: Hobart LXIH displays P2
The rinse thermistor is bad,look on the back of the machine to the right and you will see 2 black wires with a plug that screws into the vac breaker this is the probe.I bet when the dishwasher goes into the rinse cycle the temp jumps all over,let me know.
SOURCE: E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
SOURCE: the hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
