I find the light a continuous distraction and wish to delete it
Delete both the app and its configuration profile
To delete an app and its configuration profile, follow these steps.
1.Delete the App.
·Tap and hold on the app until it jiggles.
·Then tap in the upper-left corner of the app to delete it. If you see a message that says, "Deleting this app will also delete its data," tap Delete.
2.Delete the configuration profile that came with the app.
·Go to Settings > General > Device Management, tap on the app's configuration profile.
·Then tap Delete Profile. If asked, enter your device passcode, then tap Delete.
3.Restart your iPad.
SOURCE: I can't find the ffm
i had the app but it quit working. so i deleted it and then tried to download it again but couldnt find it! i searched for other solutions and found that the app had done this once before but it started working later and was put back in the app store. dont know if it will this time though.
SOURCE: our play station wont play games,it stays on the
Hi Trudie,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
SOURCE: deleting old words with friends games on the ipad
Push and hold app until jiggliing with x.Tap x to delete from ipad.
help me please why i can not find table?it say table not found 2 month ago.what should i do?
- hold on to the icon that you wish to uninstall.
- After some seconds continous pressing, the App icons will begin to shake.
- Then tap the close button which will be denoted by 'X' symbol on the top left corner on one of the icons you wish to delete
- You will be prompted whether to delete the application.
- You will have to click on the delete button.
- If you wish to re-install the application later again, you will have to go to the App Store and then download again.
How to Delete Web Page Links on the iPad
- After some seconds of continous pressing, the App icons will begin to shake!
Delete the App.
1. Tap and hold on the app until it jiggles.
2. Then tap in the upper-left corner of the app to delete it. If you see a message that says, "Deleting this app will also delete its data," tap Delete.
1. Go to Settings > General > Device Management, tap on the app’s configuration profile.
2. Then tap Delete Profile. If asked, enter your device passcode, then tap Delete.
Restart your iPad.
