SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
SOURCE: where to tighten belt on reebok280 treadmill?
there should be 2 end roller caps, one on the left and one on the right. in these caps there will be an allen key bolt, turn each one a full turn to tighten the belt. continue to turn these bolts until you are happy with the belt tension.
SOURCE: My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you Repeat until the walking belt is centered.
SOURCE: Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill
and the other is to tighten the belt.
There should be two bolts
in the rear of the treadmill, one on each
side. These bolts adjust the rear roller of the treadmill. The walking
belt will always go to the side that is looser. To get the belt back
on track, (if you can start the treadmill so the belt is running)
tighten the bolt on the side that the belt has slipped to. Tighten the
bolt a little bit at a time. If you tighten the bolt too much, then the
belt will go to the other side.
To tighten the belt, start by
locating the two bolts that adjust the
rear roller (one on each side of the unit in the back). Run the unit at
about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that
what you do to one side, you MUST do to the other side or the belt will
get off center. After you tighten it 1/4 turn, check the belt to see if
it is still slipping. If it is then tighten the belt 1/4 turn again.
Continue until the belt does not slip, but do not tighten the bolts more
than 2 full turns.
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
