Old hand control worked, but was falling apart, loose wires etc so replaced it - meanwhile it's stuck in the down position and can't be used.
SOURCE: 2001 Nissan Altima - Seat Back stuck in the recline position.
where is the overload protection circuit for power seat of nissan altima 2001 , the seat does not move back and front let me know if i could do the seat move
SOURCE: camry power driver seat motor won't return from recline position
it has three septet motors with gears
if one is bad you will replace it
SOURCE: The recline on my power seat stopped working
I just bought a 2005 Nissan Altima that had the same problem. The motor was fine. I opened the switch and found that a trace on the small circuit board was cut/missing. I soldered it on the spot and it solved the problem. You can access the switch by carefully prying off the switch buttons, then the plate. There are two screws that must be removed so that you can pull the switch assembly out of the seat.
SOURCE: The driver seat is in the recline position and
I have G35 coupe and it's on a recline position. The car seat won't come up?
If it is fully reclining you need to leave a little bit more than the height of the chair's back. For example: if the back height is 19", then you need to leave about 20" between the chair and the wall behind it.
