I don't generally like to work on 2cycles. Reed valves are under the carb on the ones I've seen. I watched this whole video of a 250 being disassembled and I didn't see reed valves. It looks like a ported piston design to me aka no reed valve. I'm willing to be wrong.
Here's a complete tear down video -
Stihl MS250 Chainsaw Teardown
Here is an exploded diagram and I don't see reed valves on it.
Stihl MS 250 Chainsaw MS250 Parts Diagram
SOURCE: chainsaw running problem
The saw is not getting enough fuel. It should take about 7 pulls to hit(on choke) and then another 2 too start(on run).Check the fuel line and filter first,a fuel line leak is the most likely culprit, very common. Change the air filter, it's cheap and will eliminate any air related problems that may be contributing factors, and it probably needs to be done anyway. If this does'n't fix'ya we will continue on.
Please rate!
I'm assuming the carb is not adjustable, if it is we can solve this in about 30 seconds-
SOURCE: removing flywheel and clutch assembly ms 250 stihl
You need a piston stop, watch part of this to explain use:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Make one with starter cord or rope:
I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. HTH
Lou
Testimonial: "Thanks for your help, I got the clutch assembly off with the rope as a cylinder stop. But the flywheel is going to require a puller i think."
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
SOURCE: clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
SOURCE: stihl ms 250 dies after starting
does the engine feel like it has compresson?is there spark? if so remove the muffler and try to start it if so open the muffler and clean the screen inside
