Question about Haier Refrigerators
Haier HB25FSSAAA fridge - The water is not getting from the refrigerator's water reservoir assembly to the icemaker in the freezer drawer.
If I fill the icemaker with water (manually) it does create ice cubes, but it doesn't seem to draw water on its own from the water tank.
  • Dan Vas
    Dan Vas May 04, 2018
    Eventually the mainboard was replaced - now everything works.
    Top Expert:
  • Haier Master
  • 10,321 Answers
Water solenoid bad
Posted on May 04, 2018
    Habit-Forming:
    New Friend:
  • 21 Answers
It is most likely your water valve
RF 7800 06 Haier Valve Water Assembly
Posted on Jan 12, 2018
Testimonial: "I think my model doesn't have that valve. It is not connected to a water supply, it has a water tank in the refrigerator that is filled manually."
SOURCE:
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
SOURCE: Leaking icemaker
You may want to check that your water line isn't cracked.
Ours cracked and now we need to replace our floor. The water line is too close to the compressor which heats the plastic tubing and makes it brittle. Our refrigerator is 9 years old. Model #TPX24BRYFBB
Good luck
Posted on Dec 02, 2007
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
ginko
  • 19396 Answers
SOURCE: Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
ginko
  • 19396 Answers
SOURCE: Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Whirlpool ET18GKXDN05 refrigerator water in bottom of fridge under drawers.
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Sep 26, 2011 | Refrigerators
GE Profile PSC25SGSC coil/cooling compartment freezes up behind the fresh produce drawer and does not allow air to flow though climate keeper tunnel to cool the upper portion of fridge. Temperature...
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
Leo Ponder
imufo2
Sep 25, 2011 | GE Refrigerators
My side by side ge profile refrigerator is causing grief. It starts by water freezing not allowing the water dispenser to work. Then it begins to defrost the freezer side. I also notice that anything in...
Leo Ponder
imufo2
Sep 23, 2011 | GE Refrigerators
My Haier HVW18 Wine Cellar has a top fan which makes a great deal of noise and a bottom fan that does not work at all. This appears to be affecting its ability to maintain temperature. Any ideas?
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
Leo Ponder
imufo2
Sep 21, 2011 | Haier HVW18A Wine Cooler
Whirlpool side by side fridge freezer, fridge compartment not working. control is fully open to allow cool air into fridge compartment. freezer is working normally.
EASY JOB.
Leo Ponder
imufo2
Sep 16, 2011 | Refrigerators
Bpl f 202 vx model fridge. main fridge is not getting sufficient cooling and freezer gets over cooled.prior to this complaint the fridge was making big noise.
EASY JOB.
Leo Ponder
imufo2
Sep 13, 2011 | Refrigerators
My produce keeps freezing in the crisper drawer-the temp in the fridge is set on medium (5) and the humidity level is on the middle setting in the crisper drawer.The drawer is not jam packed with...
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Sep 09, 2011 | GE Profile PDS22SBRR Stainless Steel...
After an extended period of non-use, i attempted to start using my fridge again only to have the fridge section not get cold. the freezer section works fine, but fridge will not get cold. what do you...
EASY JOB.
If
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
I i'am getting ice in tthe freezer part, in the front of the trays were the food goes,and around the drawers. The refrigerator is 2 doors at the top. and the freezer is 1 drawer at the bottom with 2...
Leo Ponder
imufo2
Aug 18, 2011 | Refrigerators
WHY DOES THE DRAIN TUBE KEEP FREEZING UP AND FRIDGE LOSES TEMP AND DRAWER FILL WITH WATER
Does it have an icemaker. It may be leaking through the water valve and causing excess water to freeze
Jul 08, 2011 | Whirlpool ET1MHKXM Top Freezer...
Refrigerators Logo
95 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
