E4:
incline
wire
1.incline motor VR wire not on right position.
1.rework the VR cable head to be sure on right position.
2.incline motor AC wire not on right position
2.incline motor AC wire insert again to be sure right.
3.incline motor connect wire is broken.
3.change connect wire or change the incline motor
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
SOURCE: error code 3
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
SOURCE: Treadmill error code 4
You will need to give more detail, like make and model numbers? without that information there is really little help anyone can give except contacting the manufacturers website for the manual to download.
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions
Things You'll Need for to Reset Code:
1.
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill
