We apologize for the inconvenience. We'll be glad to further review. Please email us at [email protected] at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Sorry only the way is to consult the manufactures website and complain eric
SOURCE: 3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
SOURCE: Grinding during the spin cycle
To check for a bad bearing, open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad. If OK, the noise may be coming from the pump. The pump impeller may have come loose and is rubbing on the pump housing.
To check impeller, remove the bottom access panel. There you will find a pump filter that you can unscrew and remove debris. UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Look inside the small hole of the pump and check impeller, it should be set back against the motor.
If bearing, check limited warranty.. bearing may still be covered...
Regards,
Richard
SOURCE: Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
SOURCE: my gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
