Question about KLH Audio Players & Recorders
I need a(1) tweeter that's missing from klh #514S-AW speaker.
Would like specs for tweeter
SOURCE:
  • 238 Answers
SOURCE: KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Posted on Jan 12, 2008
tech240
  • 169 Answers
SOURCE: i need a tweeter or the specs for a hi freq.
Try this link
http://www.jblpro.com/pages/recording/4400.htm#4412A
Thanks for using FixYa, I hope this helps.
Posted on Oct 23, 2009
SOURCE: Need parts for sansui as-300 speakers
Have spare parts from AS 300 Sansui Speakers. Call me Alan Mertz 941-387-0675
Posted on Feb 11, 2010
SOURCE: can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Posted on Apr 09, 2010
Grubhead
  • 5683 Answers
SOURCE: I have KLH Model 32 speakers, from the early
You need to replace the tweeter sorry!
Posted on Oct 07, 2010
I bought a pair of Mordaunt Short Qviano 1 speakers from Richer Sounds 18 months ago and now find that the tweeter in both units has failed. The amplifier I am using is rated at 70 watts which is within...
Specs refer to UNdistorted sound. Send square waves to any speaker and it will die eventually, perhaps even the amp.
You are more likely to blow up speakers with an under-powered amp pushed to hard than a monster amp running well within its capacity. Distortion percentages rise vertically once the amp's useful range is exceeded. Tweeters are usually the first casualties.
It's tweeter hunting time.
http://www.mordauntshort.com/support.php
http://www.mordauntshort.com/assets/documents/Aviano2TechSpecs.pdf
Aug 10, 2011 | Audio Players & Recorders
I have a klh 116615p bg11 12 sub and need to know the watagew it doesnt say
This woofer was taken from a KLH Pro-71 Series. These were the top of the KLH line from ~94-99 when it was still a real company and not just a name. The woofer is rated for 5-350 watts at 8 ohms. Source: KLH Pro Series-71 Spec Sheet.
Apr 06, 2011 | KLH Audio Players & Recorders
I need a tweeter or the specs for a hi freq.
Try this link
Oct 22, 2009 | Audio Players & Recorders
Can't find specs/maker of klh 900b tweeter
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
Jan 11, 2008 | KLH HT-9930 System
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
56 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
