SOURCE: When we select Scan to File and choose pdf file
Correct! Its a PDF but its just a picture of the characters you will have to OCR it to use the search feature. Good Luck E-Copy is a good program for doing this or Laserfish
SOURCE: Conversion of .pmd extension files to PDF format
sir,
i do below way (little bit lengthy process)
I have installLinotronic 930 v52.3 printer on my pc which generate PS file format. PS file should be converted to pdf by using Acrobat Distiller 5.0.
You can print to pdf in Windows. It will be something like the following.
When you finish your file...
1. Click on file in the top menu.
2. Click on Print.
3. Change your printer to PDF.
4. Click print.
5. Choose your location for your file.
6. Name your file.
7. Click Save. You will have a pdf file.
