Hello, Nancy -
If you think you will ever need to convert metric measurement to
"English" measurement (used in the USA), this is a great web site (for all kinds of conversions):
http://www.metric-conversions.org/volume-conversion.htm
This is the link to the home page for conversions:
I suggest you save that web page address to your Favorites / Bookmarks.
Using the conversions calculator for milliliters to U.S. fluid ounces, this is the result:
50 ml = 1.690701 U.S. fluid ounces
This is the result for U.K. fluid ounces:
50 ml = 1.759754 U.K. fluid ounces
I assume your question has to do with liquid perfume.
0.50721
SOURCE: ONE TROY OUNCE EQUALS HOW MANY CUBIC INCHES?
1 troy ounce =31.1035 grams
454 grams = 1 lb
gold weighs .3091 lbs/cubic in
therefore 1 troy oz = 0.2216 cu in
SOURCE: 7 pints equals what in
Metric what, Liters, milliliters?
1 1/2 pounds converted to what grams, kilograms?
Your answers whatever the values are can be found from any of hundreds of online converters.
You pick the value that you want converted and the value you want it converted to.
One that will work is:
http://www.onlineconversion.com/volume.htm
Good luck, thanks for using FixYa.
SOURCE: What type of calculator or calculation formula do
ummm... every 1 lb of wax needs 2 ounces of fragrance ...you answered it yourself
