For a weeK my SCEPTRE can'r hold channel 19-(1-7) They pixelate, vocally break-up & disappear. I've reset & re-scanned many times. Last time I got a whole new series under channel 11 but lost all 19.
Do you have an outside antenna? If so start scanning for individual channels at 000. Move 5 degrees scan for individual channels again. Move 5 degrees more. You must scan for individual channels. A wide range scan will erase everything else.
Go to Menu. Hit 7343 then mute. This should take you to a menu with a single scan option. It will take a very long time to complete this. Once you have scanned in every direction, be sure to NEVER hit the wide scan.
SOURCE: my radio off frequency
is this set AM and the recievers FM? if so there will be no way round the 'problem' BOB
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
SOURCE: Hi Since last week I'm having problems with my
Reset is removing power cord from the wall plug. Without electricity for five minutes will reset the semicinductor memory and reload with the correct firmware when you turn on again. This is due to glitches on the power line, some people may use powerline filters to avoid any future problems..
