SOURCE: BIOS detects only 128 MB instead of 1024 MB
Can you try the memory sticks in another PC.
Did you get them from a reputable dealer.
I have known people buy what they thought were 1 gig ram and got fakes. i.e. 512 or 256 meg.
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
SOURCE: I insert a memory stick and it says
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
SOURCE: I tried to open my USB flash drive stick after a
have you tried another computer.if yes the drive is probably no good.
SOURCE: I have successfully used one
Depending on how the flash drive is formatted the picture frame may not be able to understand the information on the flash drive. Check the operators manual of your frame for the correct format your flash drive needs to be in order for the frame to read the files. Most of the time formatting to FAT is the safest option
Testimonial: "Very helpful in direting me to look at the formatting of the stick - problem is it is formatted to FAT as is the stick which works OK. No real progres"
