Coffee Makers & Espresso Machines Logo
A
Alexandra Wise Posted on Jan 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cleaning the interior, especially the bottom where heated milk gets burned on.
Mark Cheong
Level 3:
Master:
  • Coffee Maker... Master 791 Answers
  • Posted on Jan 11, 2018
Mark Cheong
Level 3:
Master:
Answers
791
Questions
0
Helped
475589
Points
2475
90% of all my service calls were due to machines that were not cleaned DAILY. About a third of those were for espresso machines with a steamer and the rest for auto frothers. Most Barista's don't use auto frothers as they have very little control over the frothed milk. (Heat, froth density, firmness, holding, etc.) Milk(any type) will clog a machine in minutes if not cleaned up after use. Spoiled milk will contaminate any product with curds and have a bad smell to coffee.
* Clean up after any milk usage. Seconds count after frothing milk with a steam wand. Get workers in the habit of removing milk pitcher from wand and give the wand a short blast to flush the wand and wipe with a damp towel (tower wash and sanitized often) Leave the folded (quartered fold) next to wand on drain tray where it's always handy.) It only takes seconds to perform and customers appreciate the cleanliness and professional look.
* take a tip from Bartender's; you HAVE TO WASH WITH DETERGENT! when washing glasses that had milk drinks in them. Nobody want's a sour milk smell in any drink. Milk film can only be removed with soap and water and a brush. That's why you see automatic cup washers on every bar set up. It does take elbow grease to get these cups clean.
* Harden, cooked milk (coffee to) is best soaked in clean water (detergent optional) and let it sit over nite. This is a good practice to keep everything coffee/milk stain free as everything is washed/rinsed prior to use in the morning.
* Really, really baked on coffee (left burning on warmer for several days, weeks. Will need an urn cleaner to soak and wash out several times. Check with your coffee vendor as most will just swap them out with clean ones. Otherwise ask for urn cleaner from them and follow instructions. Hot water with a tablespoon of urn cleaner for each pot and let soak over nite. wash and rinse thoroughly prior to use.
"Washa-washa!" Aloha! ukeboy57
1 Related Answer
Pierre Laplante
  • 2061 Answers
  • Posted on Jan 16, 2009
SOURCE: saeco magic deluxe
use a little steel wire in the hole in the pipe to remove old milk residue you dont have to go to deep in the pipe 1 or 2 inch inside you have to remove the black plastic piece that goes in the milk thanks pierre
Miele cva 4066 milk froth isn't working. I have taken apart and cleaned the milk ducts manually twice, but it has not resolved the problem.
Have you cleaned both the machine and the flask? Dried milk is difficult to clean especially if its a flavored creamer due to the sugar content. Soak the flask lid in hot water and try the milk cleaning tablets
Can't clean out spilled (and now sour) milk spill
Hi, I'm not familiar with these fridges, but is it possible to access it from the back, underneath the evaporator tray? It could even be that the milk has gone down the drain hole and into the evaporator tray itself. Its a small flat plastic tray that has raised sides, and will probably have water in in, sits just above the motor
9helpful
2answers
The milk doesnt heat up or froth but the button flashes red
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
I purchased a Bialetti JC91 Hot Chocolate Maker a few weeks ago. The problem I have is cleaning the burned milk from the bottom of the pot without risking scratching the non-stick surfac. Any ideas?
Pour lemon juice and vinegar in equal parts - about to a fifth of its capacity - in the pot and heat it up for a few minutes. Unplug the unit and wait 15 minutes for the mixture to cool down then use a wooden spoon to scrape it off.
Oct 09, 2010 • Vacuums
42helpful
7answers
Burnt Milk at Bottom of Aeroccino
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
25helpful
Doesn't heat completely and light blinks
This is either a problem with the thermostat that lives just under the surface of the bottom of the aeroccino jug and is a technical problem that can only be resolved (replaced) by returning it to Nespresso OR it is related to a fine layer of burnt milk that builds over successive use that builds and holds the heat the element produces 'tricking' the thermostat into thinking the milk itself has heated to the desired temperature, not just the burnt layer. Clean the bottom of the jug, regularly with a non scratch scourer and use a mild detergent as well.
81helpful
17answers
Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
GE PDS20MBS
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
