Cameras Logo
A
Anonymous Posted on Jan 10, 2018
Why dont curtisy lights come on my jazz when I open door
When I open any door curtisty lights do not come on
Bill William
Level 1:
Habit-Forming:
New Friend:
  • Contributor 21 Answers
  • Posted on Jan 10, 2018
Bill William
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
21
Questions
0
Helped
11825
Points
95
The frame around your front doors have a switch in each one the switch may be bad or it could be a fuse. Chech the fuse first it is cheaper to replace. The owners manual will tell you what fuse number it is. And the switch
Amazon com 35400 s5a 013
David Legender
Level 2:
Habit-Forming:
New Friend:
  • Expert 88 Answers
David Legender
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
88
Questions
0
Helped
24431
Points
283
Switch on courtesy light in wrong position,
1helpful
2008 Honda jazz interior lights not working when opening the doors
this is due to the fact that a fuse might be bad or the switches on the door you trying is bad.
Honda Jazz (2007) with a non-working interior light
Jacker
conner you are 10 years late.
so manual on fails
and door open dome fails, and the switch not set to ALL MOdes off?
hhhhhhhhhhhh read the users guide on dome lamp.
oops no jAZZ in USA, so no books
most cars 2007 the lamps are BCM body brain operated
and have no dedicated fuse to DOME at all, like seen in the 1990s' back.
the best I can guess is the head lamp switch if you looked close has dome option. there.
on, off, auto
off makes it dead all the time
auto makes door switchs turn on dome.
most cars are in fact fully programmable by you and is cover in the jazz operator guide in the glove box day1, new, lost it?
HONDA has it ,ask them, it is free.
here are the words you never read,in the glove box
as you can sees this is no 1990 are it has a brain now.
that fools many now.(then) this magic prevents battery dead.
we love it, for sure stranded by lamps left on.
Temperature of refrigerator rising
you have a defrost problem!!!the evaporator coil is getting covered with ice and the evap fan can't blow the cold air from the freezer into the fridge section,you could have a bad jazz board,the machine isn't going into defrost this is your problem send me the full model number,it should be up on the right hand side wall up near the ceiling in the fridge section,if you have the control up in the fridge section on the front top and it's digital saying like 4 and 4 you most likely have a bad jazz board,if so open the door or if you have french doors open the right door,hold the light switch in,press the down key three times,let go of the door or light switch,now press the button down again and you'll see like s and p or something like that then press it down again and it should go back to 4 and 4 shut the door and open the freezer,you just manually put the fridge into defrost,but if the compressor is still running and you'll hear it this is the easiest way to tell the jazz board is bad,after like 5 minutes you should hear the ice crackling if the board is good,that's the heater coming on melting the ice but send me the model number and i can help you out.
1helpful
Where is the battery door on my Jazz DVZ100 located and how do I open it
It's on the side of the camera opposite the flip-out LCD. Push the round button just behind the rubber lid covering the connection ports to unlatch it.
1helpful
2answers
What the heck does the ctsy fuse supply power to
COURTESY (ctsy). Interior light inside the car. Hope this helps...please vote for me...Thanks.
4helpful
What does it mean when all the lights are flashing on the control center and the ice dispenser door keeps continuously opening and closing?
you have a big problem . they call it the jazz board . the main control will have to be replaced . this is only correcto to the problem .. mm
1helpful
Camera has no display, appears to be locked up
When i open my Jazz Elite 179 the screen is just a light white blank screen..what does this mean?
I dont know how to get music on my jazz HDV178 video camera
Connect it with the USB cord, and explore the sd card... There will be a folder on it which says music. Open the folder and just drag & drop!
LCD door wont open when you push the power on button. Have to open it manually.
Sorry runnigdeer but you always have to open it manually! it's not all automatic this thing!!
Top Jazz Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jazz Camera Expert? Answer questions, earn points and help others
