SOURCE: kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
SOURCE: washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
SOURCE: Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
