Question about HP Computers & Internet
My hp computer model a6750f prod fq563aa-aba so I can see if I can fix it.
  • Anonymous Aug 07, 2018
    it might be the on board video has quit working. If that is the case you will have to purchase an external video card that would need to be inserted in an available card slot inside the computer. Then you will need to move the monitor plug from the onboard VGA plug to the VGA plug on the back of the video card.
  • Larry Ng
    Larry Ng Aug 11, 2018
    why not post the symptoms.
    your post makes zero sense. sorry.
    if you have issues with it ever consider
    asking HP for help
    their forum costs you nothing.
  • HP Master
  • 4,603 Answers
OP is it still a problem. 8 months later?
PC dead. 11 or 12 years old is it, the RTC Cmos coin cell is dead.
PC screen dead.
windows infected.
HDD errors. (due this old sure)
beep codes
Caps lock blink codes>
noise
lost passwords. BIOS user, Admin, or windows Pw?
name something wrong. ok?
Posted on Aug 15, 2018
4 Suggested Answers
SOURCE:
DickCanFixIt
  • 948 Answers
SOURCE: What is the wattage of my HP computer?
Using the calculator here, about 275w.
Posted on Jan 30, 2009
  • 14 Answers
SOURCE: How do I transfer photos
easiest way would be to use a usb thumb drive. Better yest invest in an good external Hard drive - move all of your photo from old pc (use my computer - select folder and move) then connect the external hard drive to your new pc and "copy" to your new pc. when all done you even have a backup copy of your precious photos in external hard drive...
Posted on Oct 10, 2010
hatchet363
  • 4603 Answers
SOURCE: How do you open a hp model a6750f prod fq563aa-aba so I can see if I can fix it.
double posted, wow.
and zero facts.
what monitor is there?
the PC is dead, you said in other post.
I think you said that, but leaf off word PC.
1: does the PC make any sounds.ever?
2: do all 2 to 3 fans spin and blow air.
3: does the PC beep or flash keyboard, errors codes.
caps locks LED can blink codes on some HP PC.
i'll stop here,read you other post for all tests.
DEAD PC is the only clue so far...
windows 7 (from XP)3yr ago.
11 years old PC. yeah old.
full of lint inside NO DOUBT.
Posted on Jan 08, 2018
Testimonial: "My monitor is on the top of the computer table.Yes it does, and the fan's spin and blow air,no the pc don't flash,beep keyboard error codes. The cap locks led blink sometimes and sometimes not."
HP a6750f PC refused to boot at all after 1-1/2 weeks of use. Spent 2 hours with HP Tech phone Support - who never mentioned all of this model's identified problems (hard drive crashes/AMDRAIDX/Bios,...
Here these guides will help you!
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
If it is under warranty take it back for a replacement computer, or they can replace the faulty component free of charge.
May-be resetting the BIOS/CMOS will bring you some joy, tell me how it goes.
Happy testing
damnor01
Jan 14, 2011 | HP Pavilion a6750f PC PC Desktop
How do I transfer photos from an old HP Pavilion 6830 CPU to our new computer, a HP Pavilion a6750f?
Oct 10, 2010 | Computers & Internet
My HP Pavilian a6750y tower when turned on fan runs , but no light on powere button and moniter is blank
Indicates you have a bad Power Supply, to me.
Weak voltage power rail.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
(The Pavilion a6750f uses an ATX power supply, that has a maximum rated wattage of 300 Watts.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01619697&lc=en&dlc=en&cc=ca&lang=en&product=3872428#N934
The AMD Phenom X4 9650 processor can use up to 95 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Agena.22_.28B2_.26_B3.2C_65_nm.2C_quad-core.29
(In the chart under the heading TDP)
Enough power to spin fan's, but not enough to turn the Processor on.
Not enough to also light that Power On LED light.
No Processor operating = No Video Signal from the computer.
Hence the monitor is blank.
(No Signal)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&tmp_track_link=ot_recdoc/c01619697/en_ca/c01356113/loc:3&lc=en&dlc=en&cc=ca&lang=en&product=3872428
NOTE*
Computer unplugged from power.
Anti-Static Precautions observed.
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
(You may not even see it, or feel it)
Computer unplugged from power, computer case open, working on a table;
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be be SURE to Touch the metal frame again.
Oct 04, 2010 | HP Pavilion a6750f PC PC Desktop
MY COMPUTER IS COMAPQ MODEL NO-SG3430IL SERIAL NO-INA8260B6S PROD#KT477AA#ACJ I DIDNT GET THE DRIVERS CD FROM WHERE I GET IT FROM
MODEL NO-SG3430IL
SERIAL NO-INA8240JT1
PROD#KT477AA#ACJ
Sep 19, 2010 | HP Compaq Motherboard
HP a6750f monitor goes to sleep without warning right in the middle of something. Disc also sleeps sometimes (I hear it wind down) but blue light still on cpu, no yellow. Was running Vista, which problem...
Well FIRST take it back and make that "Repairman" work on the problem until solved at NO extra fee. What has been done is NOT professional. Had you come to my shop, this wouldn't have happened and if it did, it would be remedied without cost, and would be worked upon until fixed. The same must apply here. You paid good money for a FIX NOT OS replacement I suspect you have a faulty component,maybe Video card maybe WiFi card etc. Please do NOT accept a run around. Try the "Honey"approach first, then "Vinegar"... if, you get any BS, from them/Him. I am sorry on behalf of us professionals.
Mar 07, 2010 | HP Pavilion a6750f PC PC Desktop
I am trying to find the HP model nunber for he dx2300. the HP format is one or two Alpha character three numberic number and one or two Alpha characters Example the HP model number for the dx2200 EN287UT
HP Compaq Business Desktop dx2300 Part #: RT843UT#ABA HP Compaq Business Desktop dx2300 Part #: RT843UT#ABA the part number for the HP dx2300 is
Part #: RT843UT#ABA
Sep 30, 2009 | HP dx2300 Monitor Personal computer Intel...
I want an upgrade on my video card...
more cpu and a better graphics card, id say get a amd athlon x2 dual core [Cpu]
And a Nvidia Gefore 8800GT
May 28, 2009 | Computers & Internet
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Open Questions:
Computers & Internet Logo
244 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
