There are many proplems is Kipor generator. And if the generator has problem, you are the better to contact your supplier or engineers.
Here are some article for your reference: www.dieselgeneratortech.com
Reasons for excitation. There's not enough remanence.
If you need to have new diesel generator set in futurer, please contact company email [email protected] directly who can supply Cummins, Volvo, Perkins, Yuchai, Shangchai diesel generator etc.
Oh, there are many people say the generator can not supply power. Maybe the fuel is not enough or other problems. I recommend you to buy diesel generator set in future, its quality is better and can use for a long time. A website for your reference: www.dieselgeneratortech.com
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
