SOURCE: power connector of T40 think pad loosen
if you think your adapter really works fine then you have a motherboard issue.
SOURCE: how long does it take to fully charge the battery
The 10A has not been sold for over 15 years. When the batteries are in good shape it took around a hour to charge. If yours is taking longer than that it could be the batteries are bad. I would also look at the contacts on the battery and the drill. These had a tendency to get bent,
SOURCE: diagram of 36 volt hookup for trolling motor
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
[email protected]
SOURCE: My Acer Extensa has a loose DC connector. The
You can just have the power plug replaced. Cheap enough and easy to do. Although if you take it to a shop they will charge you a fortune to do it
The part will cost no more than £15.00
SOURCE: mini moto atv 36 volt will not run
it probably is the interlock switch/ the black square with 2 small green wires and to large reds.replace that and should run.just bypassed mine and know it works.have fun
