Hi, I have a problem with Kenmore Eletric stove model number:790.96312401. Get the error code F10 after stove worked for 10 -15 minutes. Please advise waht part do I need to replace.
Thank you
I want to know what the f10 code is and if it is easy to fix?I want to know what the f10 code is and if it is easy to fix?
AnonymousAug 03, 2008
The F10 function constantly goes off for a long period after I use my oven. Can you tell me what to do to fix it?The F10 function constantly goes off for a long period after I use my oven. Can you tell me what to do to fix it?
Set the oven to 350 but the broiler coil comes on. If I turn it off and turn oven back on, it does the same thing again, along with an F10 error.
Model 790-94219049Set the oven to 350 but the broiler coil comes on. If I turn it off and turn oven back on, it does the same thing again, along with an F10 error.
Model 790-94219049
Model 790.47142400 buzzer has been going off for hours after I lit my toasted peanuts on fire! F10 error. (Peanuts on fire?) Cool down did not resolve it. Unplugging was not an option because it is built in with no "plug", but hitting the circuit breaker worked -- at least for now. Thanks Chris!
I have a f 10 display on my Kenmore stove and then shuts off. What to do?I have a f 10 display on my Kenmore stove and then shuts off. What to do?
AnonymousNov 26, 2008
I put my oven on self-cleaning and after an hour or so it starts beeping and F1 comes up I put my oven on self-cleaning and after an hour or so it starts beeping and F1 comes up
You can't post conmments that contain an email address.
not on that model. just unplug it first. and remove the upper back panel. its self explanitory from there.not on that model. just unplug it first. and remove the upper back panel. its self explanitory from there.
The F10 code on a Kenmore oven means that the oven is overheating - the oven is detecting a temperature far over the safe range of operation. Most models also start beeping when this happens since it can be a safety concern.Apr. 14, 2020
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Hello,Please use the chart to determine which stove you have. You will have
to look at the model number. The first 3 numbers will be the series on
the chart. In most cases an F1 error would require replacement of the
electronic control. This part is commonly refered to as an EOC or ERC.
However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric) F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper) F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool) F1-E0 EPROM Error - Electronic Range Control (ERC). F1-E1 EPROM Error - Electronic Range Control (ERC). F1-E2 U/L ERC Errors - Electronic Range Control (ERC). F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric- “9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
The F10 error code indicates a runaway oven temperature. This would
indicate that the oven temperature sensor or the electronic control has
failed. According to the service manual you need to unplug the range
& after restoring power the oven continues to overheat you will
need to replace the electronic oven control. This a job for a hands on tech!
Thank you for trusting us with your questions. Please remember to leave a solved rating before you sign out! Thank You
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Chris,
Thank you very much for your help . Is it difficult to replace it ?
Thank you
Chris,
The problem has been fixed. We are very happy.
Thanks a lot for your help
BRAND NEW STOVE 790.4019 F10 ALARM GOING OFF
Model 790-94219049
