Humidifiers Logo
A
Alvin Deckert Posted on Jan 07, 2018
Specifications for KAZ vaporizer model 101 - Kaz Humidifiers
1helpful
2answers
Where can i get a new water tank cap for vicks model V745A?
This is a POSSIBLE answer: I found the manual at the Vicks site, read through it, but it did not mention replacement parts at all. However, at the very end of the manual was this paragraph, which might serve as a way for you to get what you need. Quoting the manual:
If you have any questions or comments, call the Kaz Consumer Service Department at 1-800-VAPOR-1-2 or, e-mail [email protected] or, write to Kaz, Consumer Service
Department, P.O. Box 544, Hudson, NY 12534, explaining just how the product is operating. Specify model number. Our Consumer Service Representative will advise you how to correct the problem yourself, or will ask you to return the product for repair or replacement.
Steam vaporizer kaz, emites a black particules, in the tank like sort of blak ink when finish using it, is there any problem with that???
This is considered normal. It's the residue left from the water vaporizing into steam. Since it's left behind in the chamber, you do not breathe it in. Other users have said that it helps keeping these minerals in the chamber and just adding water to mineralize the water in lieu of adding salt.
I need a kaz steam vaporizer model 76 instruction manual
How many watts does Kaz Steam Vaporizer Safeguard Model 76 use???? I think it's using a lot of electricity. Anyone with clarity please?
Kaz 2100 Warm Steam Vaporizer was stored empty for about an year. Today I filled it with water, plugged it in, waited and waited...... no results. Wouldn't start. There is no buttons to push, nothing to...
Chances are the rubber pump inside the unit cracked and will not work anymore. This type of unit is a "Disposable" unit and is not intended for repairs. Its cheaper to buy a new one then buy parts for this.
Hope it helps.
I wanted to clean the inside of the kaz vaporizer and i took the screws out but cant get the gray plastic off help it looks like there is a lot of dried minerals inside help please
I want to clean the white gritty minerals from the fly wheel inside the humidifier. I took the three screws out but the plastic wheel will not move. I'm afraid to force it...might crack or break.
I have a vicks hot vaporizer and the unit itself gets very very hot on the outside...it didn't used to do this, so i think it may be broken. im aftraid it will burn it is so hot.
Good day. Here is the link for the manual. Please note page four which shows your issue and some solutions. Let us know what works.
http://www.google.com/url?q=http://docs.google.com/viewer%3Fa%3Dv%26q%3Dcache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%253FProductManualAction%253DrenderProductManualById%2526ProductManualId%253D5faaee9ab20669a0a26a9fb6e6bb99f8%2Bvicks%2Bvaporizer%2Bblack%2Bparticles%26hl%3Den%26gl%3Dus%26pid%3Dbl%26srcid%3DADGEEShoMFRd7NbKZtGZM-qKr0_rmMQA7bQYO-r4VBGXLFKF1WnqeeQZDdU6pMTOMcxsZMFqdAfWvECyUPTLsoW2KBMr3QBWzicSiUPyG1F8iW4Wmil0atnkfBT1ulKofnvo5HX1DBdR%26sig%3DAHIEtbS-BI2SvXCl3TTlcQduwYAGXqORQg&ei=nuZFS7_EPMiVtgf65bDrAQ&sa=X&oi=gview&resnum=2&ct=oth
20helpful
4answers
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Top Kaz Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
