SOURCE: the controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
SOURCE: only 1 side of my sunbeam H85KQ mattress pad will
If your model has two heat control thermostats, its possible that there is a fault with one of the thermostats.
Worse would be that the electric cable that runs thru the blanket is broken.
You would need specialised test equipment to find where the break is, unless you can actually feel the cable is split when you run it through your fingers.
Normally, if the electric cable is broken, the blanket is not servicable, because you would have to cut into the cover material to try find the break and replacing the cable is impossible outside of the factory.
SOURCE: I have a king sized Sunbeam mattress pad and this
Maybe the machine of yours is broken sir and you need to bring it to a technician before it's too late.
tou can check this url to find any kind of mattress:
http://www.bestmattressreviews.com/
SOURCE: Sunbeam dual control heated mattress
I have older sunbeam duel control matress pad. the control is simple with a dial that turnes for low or higher settings. it shows a red line that is small for low and gets thicker as the setting gets higher. there is a button for on and off. I set up the cover and turned on. the green on lite is flashing and there is no heat i do have it on high and it now will not turn off by the button.
SOURCE: Sunbeam mattress warmer blinking f2. What should I do.
Play it safe
Check it thoroughly
Any broken internal wires
or is it just the timer
Take it to an Electrician
Cheers Sunbeam mattress warmer YouTube
