In most every case, generally speaking, this code would indicate that the temp probe for the conditioned space has failed. Finding support for this proves to be difficult but in my 30+ years of refrigeration work, this almost always seems to be the issue. I would pursue this area first as the "P" usually means probe.
The first link is to a specific manual. The second is to the Emerson Dixell site where there is support and resources. If the site does not provide what you need, try googling by brand plus model plus troubleshooting.
try adjusting the freezer temp. control. Might need to make it colder. Had the same problem with my Kenmore. Turned the freezer just a bit colder and now it is making more than we can use. Dialed the temp. control back to where it was before and everything is back to normal.
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
