SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: affinity dryer AEQ7000EG0. My clothes
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
SOURCE: frigidaire affinity elec dryer model
Your control is faulty and will need to be replaced. Access to it is gained by removing the top panel.
Kelly
SOURCE: Frigidaire Affinity dryer not drying,
See this link and then see part number F36 for the thermal fuse location and description - verify your model number:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150159&diagram_id=1239258#d1239258
SOURCE: affinity aeq7000eg0 no heat stops
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
