I've done everything suggested on this site and several others: clean with warm water swab, clean with soft cloth, run 901 clean, run alignment, etc.
Those printers are not a very good brand as you are locked in to using only their cartridges so go out an git yerself a new printer.
Using water can really do damage, especially if it was not completely dry. Ammonia is way better, rubbing alc is ok. Try another new color cartridge, many times cartages are bad when you get them, also go to Setting / devices / and see if black only is selected as default.
SOURCE: Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
SOURCE: black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Try wiping the print head with a soft damp cloth - it works for me.
SOURCE: I have two cartridges in
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
SOURCE: Installed new ink on ip4200.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
Confirm there is no orange tape across the top of the ink tank If the orange tape is as shown in Figure (A), it is properly removed. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A). Make sure each ink tank is snapped into the printer.
SOURCE: Lexmark S405 won't print or
Please visit the Lexmark
support page to determine if your printer is affected with the printhead issue.
Also, make sure your printer is updated. The firmware update will help give you
a highly reliable print system. Click here to validate
your serial number and/or update your firmware.
