Becky Balsdon Posted on Jan 05, 2018
I have a Lanier 5010 cg printer copier fax machine and after booting it keeps saying system error 04 lt I do not have an owners manual and was wondering what it meant and how to fix it
OCMDLIN
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jan 06, 2018
OCMDLIN
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
12526
Points
52
Http://www.productmanuals.org/lp/?brand=Lanier&utm_source=adcenter&utm_medium=cpc&utm_term=lanier%20manual&utm_network={}&utm_campaign=FM+Brands+02-03+2
2 Related Answers
tommy86669
  • Posted on Dec 25, 2007
SOURCE: Error code 5010
comme caz.... si po agiustare sta mer...????
Anonymous
  • 1325 Answers
  • Posted on Dec 13, 2010
SOURCE: the printer won't work and
hi
i found the ,users guide -- but error code 5010 was not listed , just 5100
go to this link
http://www.canon.ca/support_images/RightNow_images/Multipass/MP830/mp830_ug_us_v4.pdf
1helpful
Erro #04-001
The scanner part of the printer is messed up. HP says "LSU error: #04-001. Please turn off then on." LSU = Laser Scanning Unit.
19helpful
2answers
My faxes are not printing. They seem to be connecting but they won't print.
Tips and tricks For the LEXMARK X342N
1) Faxes won't print.
Try this first....
Press <MENU> then <*> <#> on the keypad
Press <UP ARROW> and see "UTILITIES RESET SYSTEM"
Press <CHECK MARK>
and see RESET SYSTEM
Press <DOWN ARROW> and see (FAX NVRAM)
Press
<CHECK MARK> should reset the fax memory.
Try this second....
Press <MENU> then <*> <#> on the keypad and see "SERIAL NUMBER"
Press <CHECK MARK>
Press <DOWN ARROW>
<DOWN ARROW> <DOWN ARROW> and see (ERASE FFS)
Press
<CHECK MARK> should reformat the fax memory.
It will reboot. Occasionally says the FAX NVRAM is bad
when performing the boot-up self-test and corrects the problem.
2) PC LIFE WARNING message
After replacing your photo conductor kit you need to reset the "PC LIFE WARNING" message. With the front toner door open press and hold the red <STOP> until you see the "RESETTING PC COUNTER" message
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
10helpful
4answers
Error 5010
On a Canon machine 5010 is a scanner error, stuck, light burned out, etc.
3helpful
2answers
I got an error message 5010 when I was trying to fax, but can't find in the manual I have what 5010 is and how to resolve it. Thanks you!
5010 is a scanner error that you can get if the scanner lock is locked, and also if you put a heavy book on the glass and stop the scanner. Canon only sells the scan assembly as a whole unit around $150.00
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
1helpful
2answers
LD 015 SPF LANIER
Hello my friend, kindly download printer manual PDF format in this link: http://www.lanier.com/downloads/manuals/BW_MFP/ld015copyreference.pdf  In this site you can find lots of solution.
Hope it helps in your problem. If you need more assistance just contact me. Thanks
49helpful
9answers
Error code 5010
I got the error code 5010 today (scanner lock switch). I called Canon. The printer's electrical circuitry (brain) needs to be refreshed. This is similar to wireless routers and other devices. They directed me as follows: 1. power OFF the printer 2. Unplug the printer's power cord from the electrical source. 3. Wait AT LEAST 1 minute - no less than 1 minute. 4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok. Mine worked perfectly after the above steps. - Hope this helps.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
