SOURCE: Black and Decker Battery Charger
Fault Codes
Meaning of Fault Code
F01
Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load.
F02
Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair.
F03
Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual.
F04
Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual.
F05
Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation.
F06
Reverse Polarity
F07
Alternator Output is Out of Typical Operation Range
Operation Codes
I=I=I=I
Battery Reconditioning - (The letters DES will display for the first three seconds)
I-I-I-I
Alternator Voltage Check
OOO
Charger Standby
FUL
Battery Fully Charged
SOURCE: Black & Decker LITHIUM CHARGER 14.4v to 18v . 90539541. fits A1518L, HP1884L
could be either one. Have you tried another battery? If not I would recommend taking BOTH in for inspection. They have a scanner that can detect if the battery has a problem. If you need to find a service center close to you go to dewaltservicenet.com and they have a locator. Let me know if you need more assistance.
