When printing, the paper is not being drawn through the machine. I have made sure that the paper is not chewed up at the ends to begin with!
I turned the printer upside down, shook it and tapped the bottom and wehey.......problem sorted!!
Previous Post by rhoda_uk66
WOW, 7 years on and this just worked for me!! Thank you rhoda_uk66!! I've been trying to fix it for weeks - sad, but I love this printer so much - it's photo quality is amazing even compared to modern printers.
This is my 3rd Epson R300, my previous 2 died with user serviceable parts message (usually the felt pad collecting waste ink is flooded, and is not replaceable) on this one I bypassed it by pulling out the waste pipe and inserting it into an external container - make sure it has a lid (with 2 small holes in the top) and insert it into the side through a pushed out hole and secure with tape - anyway I digress, I took it outside (disconnecting my home made waste container) and gave it a good spanking upside down, hey presto, it worked!!!
I'm so sad I was even considering buying the only new one I could find for £120 - now that would have been mad!
Thanks again rhoda!
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
