SOURCE: LG DISHWASHER LD-1204W1
Try turning your tap off a bit till the noise stops but the dishwasher still fills, it can just be due to a bit too much pressure on your water valve.
hpe this helps
SOURCE: noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
SOURCE: Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
SOURCE: LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
